Market Update: Spot Rates Still Dropping — Where Can You Find the Money?
If you’ve been feeling like rates just aren’t moving in the right direction, you’re not alone. This map breaks down spot rate changes over the past four days, and the message is clear: Most outbound lanes across the country are still seeing rate declines.The red areas on the map? That’s where rates have dropped more than average. The blue spots? That’s where rates have increased, meaning shippers are having to pay more to move freight. As you can see, there’s a whole lot more red than blue.
What This Tells Us About the Market Right Now
Spot rates have been on a downward trend, and this map confirms that in the past few days, that trend is continuing.
Most major freight markets are cooling off — shippers aren’t feeling pressure to raise rates.
- Only a few areas are showing rate increases — and they’re isolated, meaning no big marketwide rebound yet.
Carriers relying on the spot market are still in a tough position — because brokers know they can push rates lower and still get loads covered.
Where Are the Best Opportunities?
I did some digging and one of the bright spots that jumped off the tape is in New York. Buffalo is emerging as one of the hotter freight markets in the country right now. The tender rejection rate there is sitting at 12.01%, more than double the national average of 5.72%. That tells us capacity is tightening — meaning there are fewer trucks available compared to the volume of freight moving out of the area. The load board data backs this up, showing strong per-mile rates on outbound lanes, with multiple loads exceeding $4 per mile. Even though rates are down in much of the country, Buffalo is holding steady as a high-demand market where carriers can negotiate better rates. If you’re looking for stronger lanes, Buffalo might be a solid place to position your truck right now, or if you are running outbound into Buffalo, it’s not a bad backhaul market at ALL. …
Running the spot market, you have to be strategic about where you go. Don’t just play the cards where they fall; have a plan. Here’s what stands out:✔ The Southeast and parts of Texas have some rate increases – A few blue patches are showing higher-than-average outbound rate growth. If you’re looking for a lane that might pay better, this is where to check first.
✔ The West is still struggling – Most of California, Arizona and the surrounding region are seeing heavy rate declines. If you’re picking up loads out West, you need to be extra careful about where you’re heading next.
✔ The Northeast is mixed – Some areas are holding steady, but most of the region is still seeing downward pressure on rates.
What This Means for Small Carriers
It’s clear that brokers still have pricing power, because there’s just too much capacity chasing too little freight. That means:✔ Stay away from falling markets – If you’re in a deep red zone, don’t expect to negotiate higher rates. Move toward better-paying markets.
✔ Don’t chase bad freight – Some of these declining markets are getting worse by the day. Know your cost per mile and walk away from loads that don’t make sense.
✔ Capitalize on blue zones – If you find yourself near a blue market, push hard for better rates. Those are the few areas where shippers are struggling to get trucks.
Bottom Line: Stay Smart, Watch the Data, and Move With Intention
This is not the kind of market where you can just run loads without a plan. If you’re booking freight, study the trends, watch the markets, and know where the rates are actually improving.Don’t run cheap freight just to stay moving — make sure every mile counts. We’ll keep tracking this data, so stay sharp and run smart.
Market Update: Carrier Numbers Are Stabilizing — But the Market Still Has a Long Road Ahead
Last week, we covered the continued shutdown of small carriers, tracking the steady stream of trucking authorities being revoked month after month. This week, we’re seeing a shift — the rate of carriers exiting the market is slowing.The latest data shows a net change of minus-132 trucking authorities, a notable improvement from previous months when the losses were much deeper. While this suggests the market is stabilizing, it does not mean we’re out of the woods just yet.
What This Chart Is Showing You
This chart tracks net changes in trucking authorities, meaning how many new carriers are entering the market versus how many are shutting down. Over the past year, we’ve consistently seen more carriers exiting than starting up, leading to reduced competition in the industry.
Now, the trend is starting to level off. That means:
✔ Fewer small carriers are going out of business.
✔ More carriers are sticking it out despite tough conditions.
✔ The gap between new entrants and exits is shrinking — but it hasn’t flipped positive yet.This is something we’re tracking closely because, historically, a declining number of carriers combined with strong freight demand leads to higher rates. But we’re not seeing that demand piece quite yet.
What This Means for Freight Rates
We’ve said this before, and we’ll say it again: Just because fewer trucks are leaving the market doesn’t mean rates are about to take off.
Here’s why:
- There are still plenty of trucks running. The slowdown in carrier exits means the industry still has enough trucks to handle existing freight.
- Freight demand isn’t increasing fast enough. If shippers aren’t pushing out more loads, there’s no pressure on rates to rise.
- Brokers still have pricing power. As long as trucks continue to accept lower-paying loads, brokers and shippers won’t be forced to bid higher.
Think of it like this: Imagine you’re in a town with 10 gas stations. If four shut down, the remaining six can start charging more because people have fewer choices. But if those six decide to stay open despite slow business, they have to keep prices low to stay competitive. That’s exactly what’s happening in trucking right now.
What Small Carriers Should Focus on Right Now
While fewer shutdowns are a positive sign, the market is still extremely competitive. Here’s how to stay ahead:✔ Stick to running higher-volume lanes – Not every market is struggling equally. Identify regions where freight volume is still solid.
✔ Minimize costs – With rates still soft, keeping expenses low is key to survival. Fuel prices are dropping – take advantage of that.
✔ Strengthen direct and broker relationships – Shippers will always pay more to reliable carriers. Avoid relying solely on load boards.
✔ Plan for the long haul – The market will turn eventually. Position yourself now by staying lean, efficient and focused on profitable freight.
Bottom Line: We’re Stabilizing But Not Rebounding Yet
The decline in carrier shutdowns is a sign that we’re moving toward a more balanced market, but we’re not there yet. Freight demand still needs to pick up before rates improve. Until then, small carriers that manage their costs and pick the right lanes will be in the best position when the market finally shifts.We’ll keep tracking these trends week by week, making sure you stay ahead of the curve. Stay sharp, run smart, and don’t haul for cheap.
Market Update: Too Many Trucks, Not Enough Pressure to Push Rates Up
One of the most important things to understand in trucking right now is capacity — which is just a fancy way of saying how many trucks are available to haul freight. If there are too many trucks compared to the number of loads available, it means shippers and brokers have the upper hand because they don’t have to fight for trucks.Right now, the numbers are showing that capacity is still wide open — and that’s keeping rates from climbing.
Tender Rejections: What They Tell Us
Tender rejections track how often carriers turn down contract freight. If rejection rates are high, it means trucking companies are busy and are rejecting contract freight in favor of better-paying spot market loads. If rejection rates are low, it means carriers are taking whatever loads they can get because there aren’t many better options out there.
Currently, the Outbound Tender Reject Index (OTRI) is at 5.62%, and it’s been falling – down 1.96% month over month and 0.2% week over week.That tells us one big thing:
🚛 Carriers are not in control of pricing. Shippers still have plenty of trucks willing to take loads at current rates, so there’s no pressure to raise prices.
Why Aren’t Rates Improving If Trucks Are Leaving the Market?
You might be thinking, “Wait – haven’t a lot of small carriers shut down? Shouldn’t that mean higher rates for those of us still running?”
Not yet.
Here’s why:
- Carriers are leaving, but not fast enough. There are still plenty of trucks available to cover the loads out there.
- Freight demand is still soft. Even with fewer trucks on the road, the number of available loads hasn’t increased enough to force rates higher.
- Carriers are accepting whatever they can get. With rejection rates this low, brokers know they don’t have to increase pay because trucks are taking what’s available.
It’s like this: Imagine you’re trying to book a hotel in a city where there are tons of open rooms. If the hotel knows there are plenty of empty rooms, they don’t have to raise prices – because no matter what, someone will take the deal. That’s exactly what’s happening in trucking right now.
With rejection rates this low, the key to survival isn’t just running more loads — it’s running the right loads in the right places.✔ Look for markets where trucks are tighter. Some regions have slightly higher rejection rates, which means better negotiating power.
✔ Shorten your length of haul. The longer haul usually comes at a discount. Shorten it up and focus on revenue per mile.
✔ Avoid deadhead whenever possible. Every empty mile eats into your bottom line. Plan your routes smarter. Even if the backhaul pays for fuel, it does just that … pays for fuel.
✔ Don’t undercut yourself. If everyone keeps taking cheap freight, brokers and shippers won’t change a thing. Know your cost per mile and hold the line on rates.
Bottom Line: The Market Is Still Tough, But There Are Moves to Make
Until more trucks exit the market or freight demand picks up, rates aren’t going to improve much. The low rejection rates prove there are still too many trucks for the amount of freight moving right now.
If you’re still running, that means you’ve already got the grit to outlast this market. Now it’s about strategy.
Know your numbers. Pick your lanes wisely. Push for better rates where you can.We’ll keep tracking these trends, so stay patient, stay smart, and keep moving forward.
Load It or Leave It: The Best and Worst Loads of the Week
Every week, we sort through the trenches of freight to find the best—and worst—loads floating around the industry. Some are worth chasing, and others? Well, you’d be better off leaving them right where they stand.This week’s “Load It” is a solid-paying lane out of Kansas City, while the “Leave It” is an insult to any truck that’s ever touched asphalt. Let’s break it down.
🔥 Load It: KC to Laredo – $3,600
🔹 Miles: 910
🔹 Rate Per Mile: $3.96Now, this is what we’re talking about. Rick sent us in a Kansas City, MO to Laredo, TX load at $3,600 puts this at a solid $3.96 per mile, making it one of the best-paying loads on the board this week. If you’re running dry van or reefer, this is the kind of rate that keeps fuel in the tank and profit in your pocket. Laredo is one of the busiest freight hubs in the country, so there’s a strong chance of finding a reload to keep rolling. If you caught this one, you made out well. We asked Rick if there were any special circumstances and it was just an endorsement requirement and a few easy additional stops. Definitely worth it.
🚨 Leave It: Charlotte to Atlanta – $0.93 CPM (Yes, You Read That Right)
🔹 Miles: 245
🔹 Rate Per Mile: $0.93
🔹 Bonus Feature: Broker fines you for not using tracking Folks, this one is straight-up highway robbery. Eric called out a Charlotte, NC to Atlanta, GA dry van load paying $0.93 per mile, just disrespectful. That barely covers fuel—let alone driver pay, maintenance, insurance, and the sanity of keeping a truck on the road. To make it even worse, the broker wants to fine you if you don’t use tracking? At less than a dollar per mile, the only fine here should be for even posting this nonsense.
Final Verdict
✅ KC to Laredo – Load it! That’s a profitable lane with room to keep running.
🚫 Charlotte to Atlanta – Leave it! That’s a slap in the face to the industry.
Want to submit the best or worst load you’ve seen? Hit us up, and we might feature it next week. Until then, stay loaded, stay profitable, and don’t let anyone play you cheap.
You can subscribe to the Playbook newsletter here.
