The Practical Breakdown: FMCSA’s Newest Rule Changes and Proposals
What the rules used to be, what’s changing and what it means for you
The Federal Motor Carrier Safety Administration pulled the pin and lobbed an 18-rule proposal grenade into the trucking world: two final and the rest open for public comment. If you’ve only skimmed headlines, you’re missing what matters: what changed, why it matters and what drivers, fleets, brokers and compliance managers need to do about it.
This is the practical breakdown of what each rule used to require, what it will (or won’t) require now and what that means for operations, enforcement and real-world compliance. You’ll also find commentary where pause or deeper consideration is warranted, especially regarding rail crossings, hazmat implications and regulatory creep (or relief).
1. Accident Reporting – Redefining ‘Medical Treatment’
What it used to be: Any visit to a medical facility that resulted in an X-ray or imaging study could push an incident into DOT-recordable territory, even if no treatment was actually rendered.
What’s changing: FMCSA is excluding diagnostic imaging (like X-rays and CT scans) from the definition of “medical treatment.” Only prescription medications, sutures or interventions beyond diagnostics will count as recordable.
Why it matters: This should reduce the number of reportable accidents, easing data inflation on company records. Fleets need to retrain safety staff on the new threshold and ensure reports don’t include incidents that no longer qualify.
2. CDL Exemptions for Dual-Status Military Technicians
What it used to be: Reserve technicians and certain National Guard personnel were excluded from CDL exemptions granted to active-duty military, despite operating similar CMVs.
What’s changing: The rule expands exemptions to dual-status military technicians under 10 U.S.C. 10216, bringing them in line with 49 U.S.C. 31305(d).
Why it matters: It simplifies operations for military units using civilian CDL-like roles, cuts training costs and aligns FMCSA with the military’s needs. It doesn’t impact civilian fleets directly, but recruiters and training vendors working with military pipelines should be aware.
3. Driver Vehicle Examination Report Disposition
What it used to be: Fleets had to return signed roadside inspection reports to the issuing agency within 15 days, regardless of whether the state actually needed or used them.
What’s changing: Fleets only return signed reports if the issuing state requests it. You still must correct violations within 15 days and document the fixes.
Why it matters: It saves time and paperwork in states that don’t process returns. That said, fleets need to stay organized and some states still require returns, so don’t treat this as a blanket rule.
4. Electronic DVIRs – Now Explicitly Allowed
What it used to be: Under general provisions, driver vehicle inspection reports could technically be electronic, but the rule language still read like pen and paper was the expectation.
What’s changing: FMCSA explicitly says DVIRs can be created, stored and signed electronically.
Why it matters: ELD platforms like Motive already offer electronic DVIRs. This clarity eliminates any question for auditors or enforcement. Fleets using digital systems now have FMCSA’s full backing.
5. No More ELD Operator’s Manual in the Cab
What it used to be: 395.22(h)(1) required every driver to carry a physical ELD user manual in the cab.
What’s changing: That requirement is being scrapped. Drivers are still responsible for knowing how to use the ELD, but manuals can live online.
Why it matters: Less clutter in the cab means less chance of citations for missing booklets. Be sure training is dialed in; inspectors may still quiz your driver on operation.
6. Auxiliary Fuel Tanks – Exemption for Small Ones
What it used to be: Gravity/siphon-fed auxiliary tanks, even tiny ones used for tools or small motors, had to meet strict Federal Motor Vehicle Safety Standards (FMVSS) fueling requirements.
What’s changing: Tanks under 5 gallons for nonvehicle purposes (e.g., trailer-mounted equipment) now get a pass.
Why it matters: It eliminates costly compliance workarounds for small tool tanks. Think hotshot trailers or construction support units. One fewer nitpick for those setups.
7. Brakes on Portable Conveyors – A Niche But Big Win
What it used to be: Portable conveyors needed braking systems that many pre-2010 units were never designed for.
What’s changing: FMCSA proposes to exempt certain pre-2010 portable conveyors used in the aggregate industry if they meet other performance and speed limits.
Why it matters: It’s a practical fix for a narrow segment. It’s a small exemption, but it will have a big impact on those affected.
8. Tire Load Markings – No More Mandate on the Sidewall
What it used to be: Tires had to be marked with load ratings, visible and legible.
What’s changing: Proposed rule drops this requirement.
Why it matters: Fleets can avoid costly tire replacement or downtime over faded markings. The tire’s performance still must meet load specs, just not legible proof.
9. Spare Fuses – Outdated Requirement on Its Way Out
What it used to be: CMVs had to carry a spare fuse for every type used in the electrical system.
What’s changing: FMCSA wants to eliminate that mandate.
Why it matters: Trucks using resettable breakers or integrated electronic systems don’t need spares. This is another cleanup rule that matches today’s hardware.
10. Vision Standards – Removing the Grandfather Clause
What it used to be: Drivers with long-standing vision issues operated under a waiver program that predated newer physical standards.
What’s changing: FMCSA proposes ending the “grandfathered” vision waiver program.
Why it matters: Existing drivers must be reevaluated according to modern standards. Fleets should review which drivers may be affected and prepare for the transition.
11. Railroad Crossing Stop Rule – This Needs a Real Conversation
What it used to be: All CMVs had to stop at rail crossings, even if warning systems weren’t active.
What’s changing: The proposed rule allows drivers to proceed without stopping at crossings with inactive signals.
Why it matters: On paper, it improves efficiency. In practice? This needs a serious pause. Will it apply to hazmat haulers and buses? Because we’ve seen an uptick in rail strikes involving CMVs. If this applies across the board, it could increase risk. FMCSA must clarify mode-specific exemptions and driver training requirements.
12. Water Carriers – Removed from the Language
What it used to be: FMCSA regulations still referenced “water carriers,” a term dating back to Interstate Commerce Commission days.
What’s changing: They’re scrubbing the term.
Why it matters: It doesn’t. But it’s nice to see some regulatory spring cleaning.
13. Self-Reporting of Violations – CDL Holders May Be Off the Hook
What it used to be: CDL drivers had to self-report moving violations to their state licensing agency.
What’s changing: FMCSA proposes to eliminate that self-reporting requirement.
Why it matters: States already get violation data electronically. It’s one less thing to chase your drivers for and one less technicality for auditors to hang citations on.
14. Rear Impact Guards – No More Labeling Citations
What it used to be: Rear guards had to carry a label showing FMVSS 223 certification. If it faded, fleets got cited.
What’s changing: FMCSA wants to remove the labeling requirement.
Why it matters: You can’t get written up for a missing label anymore, but the guard must still meet strength standards.
15. Fuel Tank Overfill – 95% Limit Removed
What it used to be: Fuel tanks couldn’t be filled beyond 95% of their stated capacity.
What’s changing: FMCSA proposes removing that cap for modern tanks with vented caps.
Why it matters: Fewer exemption requests and easier fueling but fleets must still prevent spillage due to expansion.
16. License Plate Lamps – Redundant on Truck Tractors
What it used to be: Every rear plate, even on truck tractors, needed to be lit.
What’s changing: The exemption applies where tractor plates are blocked by trailers, making them unreadable anyway.
Why it matters: One fewer violation for enforcement to hit drivers with.
17. Liquid-Burning Flares – Out with the Old
What it used to be: Flares were on the approved list of emergency devices.
What’s changing: Liquid-burning flares are being removed.
Why it matters: Reflective triangles and modern LEDs are the standard now. This rule is in line with the real world.
18. Retroreflective Sheeting – Outdated Mandate Repealed
What it used to be: Pre-1993 trailers had to be retrofitted with retroreflective tape.
What’s changing: That mandate is gone. Most of those trailers are gone too.
Why it matters: Less compliance confusion. Fleets managing older trailers should still verify that visibility is adequate.
These Are the ‘Unsexy’ Rules That Matter
This is the real work of compliance. Understanding what used to be required, what’s changing and how to prepare separates the reactive fleets from the resilient ones. If you’re a fleet manager, broker, safety director or driver trying to stay ahead, this is your playbook. These aren’t headlines. These ripples turn into waves, and how you respond defines your risk, audits and viability in the year ahead.
Rob Carpenter
Rob Carpenter is an independent writer for FreightWaves, "The Playbook," TruckSafe Consulting, Motive, and other companies across the freight, supply chain, risk and highway accident litigation spaces. Rob Carpenter is a transportation risk and compliance expert and WHCA member covering White House policy, tariffs, and federal transportation regulation impacting the supply chain. He is an expert in accident analysis, fleet safety, risk and compliance. Rob spends most of his time as an expert witness and risk control consultant specializing in group and sole member captives. Rob is a CDL driver, former broker and fleet owner and spent over 2 decades behind the wheel of a truck across various modes of transport. He is an adviser to the Department of Transportation and a National Safety Council, and Smith System driving instructor.
