The Best Way To Maximize Fleet Longevity That You’re Probably Skipping
Grease costs pennies. The components it protects cost thousands. Here's why lubrication intervals matter more than ever.
There’s nothing glamorous about a grease gun. It doesn’t have the technological appeal of telematics, the regulatory weight of ELD compliance, or the strategic complexity of route optimization. It’s a tube that squirts lubricant into fittings. And it might be the single most important maintenance tool in your shop.
During the supply chain chaos of the past few years, fleets that historically cycled out equipment at 500,000 to 700,000 miles suddenly couldn’t source replacement trucks. Lead times stretched to 18 months or longer. The solution was to extend asset life to a million miles, sometimes 1.5 million, or park the freight.
The fleets that pulled it off weren’t running magic equipment. They were running well-maintained equipment. And proper lubrication was where it started.
What You’re Actually Protecting
Every grease point on a Class 5 through Class 8 truck exists because metal is moving against metal, and without lubrication, that contact generates heat, friction, and eventually failure. The components aren’t cheap to replace, and the downtime while you’re replacing them isn’t cheap either.
Upper and lower kingpins control steering precision and suspension movement. When they run dry, you get sloppy handling and accelerated wear, putting your driver in a compromised position. Drag links connect the steering gearbox to the wheels through ball joints that will wear themselves out without regular lubrication.
Slack adjusters and S-cams are the heart of drum brake systems. Let them go without grease and you’re looking at reduced braking efficiency, the kind of thing that shows up in a post-crash investigation when someone asks why your stopping distance was 40 feet longer than it should have been.
Tie rod ends maintain steering alignment under heavy use. Spring pins and shackles support the suspension system and will happily destroy themselves through metal-on-metal contact if you let them. The fifth wheel pivot and plate need lubrication to articulate smoothly and reduce friction between the trailer and tractor.
None of this is complicated. All of it gets overlooked when shops are busy, drivers are pushing to make appointments, and nobody’s tracking intervals.
Not All Grease Is Created Equal
Trucks operate across temperature extremes, load conditions, and environmental exposures, requiring different lubricants for different applications. Using the wrong grease isn’t much better than using no grease at all.
Lithium-based grease performs well in high-load applications and resists both heat and water penetration, making it the workhorse choice for most general fleet applications. Molybdenum disulfide grease, moly grease, is formulated for high-friction contact points, such as kingpins and tie rods, where you need maximum wear protection.
Synthetic grease tolerates temperature extremes better than conventional options, which matters if you’re running equipment through Arizona summers or Minnesota winters. And if you’re operating refrigerated trailers hauling food products, you’re dealing with food-grade grease requirements that aren’t negotiable from a regulatory standpoint.
The OEM maintenance manual specifies what goes where. Follow it. The cost difference between grease types is negligible compared to the cost of a premature component failure caused by someone grabbing the wrong cartridge.
The Tools Have Gotten Better
The manual pump grease gun your grandfather used still works. It’s also slower, more physically demanding, and prone to inconsistent application pressure. Battery-powered grease guns deliver uniform pressure, reduce operator fatigue, and make it easier to reach fittings in awkward locations. For fleets with the budget, automatic lubrication systems eliminate human error by greasing key components on a programmed schedule.
The technology isn’t the point. Consistency is. However, when applying grease, you need to do it at the correct intervals on every fitting, every time. That requires tracking.
Why Intervals Get Missed
Greasing doesn’t generate revenue. It doesn’t move freight. It’s a task that keeps a truck out of service for an hour when it could be earning. In a capacity-constrained environment, there’s always pressure to skip the PM and keep rolling.
That calculus works right up until it doesn’t. A dry kingpin doesn’t send you a warning light. A worn tie rod end doesn’t throw a fault code. These components degrade gradually until they fail suddenly, usually at the worst possible time, leaving an expensive tow bill and a missed delivery in their wake.
The fleets that maintain asset longevity build lubrication into their preventive maintenance programs with the same rigor they apply to oil changes and brake inspections. They track intervals by mileage or hours, they document completed tasks, and they hold technicians accountable for hitting every fitting.
Modern fleet maintenance software makes this easier than it used to be. Automated reminders, digital maintenance logs, and consolidated task scheduling mean there’s no excuse for letting intervals slip. But the software only works if someone’s actually using it.
The Math That Matters
A cartridge of quality grease costs a few dollars. A complete PM service, including lubrication, runs a few hundred. A kingpin replacement runs $1,500 to $3,000 in parts and labor. A steering component failure that causes a crash runs into the millions when you factor in litigation, insurance impacts, and potential out-of-service orders.
Beyond the direct costs, proper lubrication affects fuel efficiency. Components that move freely require less energy than components fighting friction. It affects driver safety, steering and braking systems that operate as designed to protect the person behind the wheel. It involves compliance because DOT inspectors routinely assess component wear during roadside inspections.
There’s no regulatory requirement that you grease your trucks on a specific schedule. There’s also no regulatory requirement that says you have to stay in business. One tends to follow from the other.
The trucking industry loves to talk about driver shortages, rate pressures, and regulatory burdens. Those are real challenges. But the fleets that consistently outperform their competitors tend to do the boring stuff right. They maintain their equipment. They track their intervals. They don’t skip the grease job because a load is waiting.
When new equipment was impossible to source, the difference between a fleet that survived and a fleet that struggled often came down to whether their existing assets could handle another 500,000 miles. That longevity didn’t happen by accident. It happened one grease fitting at a time.
Your maintenance program either includes rigorous lubrication intervals or it doesn’t. If it doesn’t, you’re not saving money. You’re borrowing it from future repair bills.
Rob Carpenter
Rob Carpenter is an independent writer for FreightWaves, "The Playbook," TruckSafe Consulting, Motive, and other companies across the freight, supply chain, risk and highway accident litigation spaces. Rob Carpenter is a transportation risk and compliance expert and WHCA member covering White House policy, tariffs, and federal transportation regulation impacting the supply chain. He is an expert in accident analysis, fleet safety, risk and compliance. Rob spends most of his time as an expert witness and risk control consultant specializing in group and sole member captives. Rob is a CDL driver, former broker and fleet owner and spent over 2 decades behind the wheel of a truck across various modes of transport. He is an adviser to the Department of Transportation and a National Safety Council, and Smith System driving instructor.
