Running on Ice: Heart transplants get a second life
In this edition: Heart transplant success research, pharmaceutical supply chains get a lift and Chobani moves into the freezer aisle.
In this edition: Heart transplant success research, pharmaceutical supply chains get a lift. Photo: Vector_Leart/Shutterstock)
All thawed out
(Photo: Vector_Leart/Shutterstock)
There has been some new research around organ donors. Researchers have discovered a molecular process that occurs when donor hearts are preserved in cold storage, which contributes to failure after transplant, a study in both humans and animals shows. The team, a collaboration between Michigan Medicine and Mayo Clinic, also found a therapy to reduce that damage using medication that is typically prescribed for high blood pressure.
The current transplant process typically involves a cooler of ice, after the organ has been infused with a cold preservation solution. The longer the heart is stored like this, the higher the chances are that a transplant will have issues and additional complications post-surgery.
“When a donor heart is stored in the cold, physical changes occur in cardiac cells that cannot be seen by the naked eye,” said senior author Paul Tang, M.D., Ph.D., a heart transplant surgeon who conducted research with collaborators at both the University of Michigan Health Frankel Cardiovascular Center and the Mayo Clinic in Rochester, Minnesota.
“We observed special protein behaviors during cold preservation at the molecular level that accentuate harmful signaling and cause donor hearts to weaken following transplantation. Disrupting this process can greatly improve a donor heart’s resilience to ischemic injury and its function after transplantation.”
There is a chance that similar processes could be implemented into different organ transplants, but more research is needed to prove that theory.
To keep up with all things cold chain and to get the full edition of Running on Ice, subscribe to the newsletter.
Mary O'Connell
Former pricing analyst, supply chain planner, and broker/dispatcher turned creator of the newsletter and podcast Check Call. Which gives insights into the world around 3PLs and Freight brokers. She will talk your ear off about anything and everything if you let her. Expertise in operations, LTL pricing and procurement, flatbed operations, dry van, tracking and tracing, reality tv shows and how to turn a stranger into your new best friend.
