New Engine Oil Standards Are Coming — Here’s What Truckers Actually Need to Know
New truck engines are coming in 2027, and that means new oil standards — here’s what owner-operators actually need to know without the technical jargon.
As engine standards change, the oil that protects them has to change too — especially for drivers buying new trucks in the next few years. (Photo: Jim Allen, FreightWaves)
Starting January 1, 2027, new heavy-duty diesel engines will hit the road. And when engines change, oil has to change with them. That’s the entire story. Under upcoming EPA regulations, heavy-duty diesel engines must achieve significant emissions reductions: an 80% decrease in nitrogen oxides (NOx) and a 50% cut in particulate matter. Furthermore, these rules mandate longer service lives and extended warranties for both engines and aftertreatment components, such as DPF and SCR systems.
The oil industry isn’t doing this for fun, and it’s not some marketing gimmick. The engines coming in 2027 will run hotter, cleaner, and under tighter emissions rules, which means the oil inside them has to do more work than the oil we use today.
Why This Is Even Happening
Every time the government tightens emissions rules, engine manufacturers redesign engines. That’s what’s happening again.
The 2027 engines will:
  • Run hotter
  • Use more advanced emissions systems
  • Push for better fuel economy
  • Put more stress on internal engine parts
The oil we use today (CK-4 and FA-4) wasn’t built for those conditions long-term. So the industry is creating a new oil standard to match the new engines.
That new standard is called PC-12, and it officially goes live in 2027.
Two New Oils — Not One
This is where some people may get confused, so let’s slow this down.
There will still be two oil types, just like today. The difference is what engines they’re meant for.
Option 1: The “Safe for Older Trucks” Oil
This oil is meant for existing trucks and mixed fleets. If approved, this oil will replace what most of you use today and will be safe for older engines.
Think of it as: “The new version of what I already run.”
This option exists so owner-operators don’t have to overhaul their entire maintenance program overnight.
Option 2: The “Only for New Engines” Oil
This oil is only for trucks designed for it.
These are lower-viscosity oils made to help brand-new 2027 engines squeeze out fuel economy and meet emissions requirements.
This oil:
  • Will not be for older trucks
  • Will likely show up in new truck owner manuals
  • Will be required if the engine manufacturer says so
Putting this oil in the wrong engine could cause wear issues or warranty problems.
The Key Date to Remember
January 1, 2027. That’s when these new oils can officially be sold and licensed for use.
That does not mean:
  • You need to change oil tomorrow
  • Your current truck suddenly becomes obsolete
  • Shops will force a change next year
It means the next generation of trucks will start showing up with different oil requirements.
What This Means for Owner-Operators and Small Fleets
Here’s the practical takeaway:
  • If you plan to keep your current truck for several more years, changes will be minimal.
  • If you plan to buy a brand-new truck in 2026–2027, this is when you can expect to change gears around oil.
  • Mixed fleets will need to be careful not to mix oils across trucks.
  • Shops and drivers will need to actually read engine specs, not guess.
The biggest risk isn’t higher oil prices. The biggest risk is using the wrong oil in the wrong engine.
The Simple Rule Going Forward
If the engine is new → follow the engine manufacturer’s oil spec
If the engine is older → use the backward-compatible oil
If you’re not sure → ask before you pour
This isn’t complicated once it’s explained correctly. New engines require new oil standards. The industry is just finally saying it out loud.
Adam Wingfield
Adam L. Wingfield is the Editor in Chief at FreightWaves and the Founder and CEO of Innovative Business Development Group, Inc. — the parent company behind Innovative Logistics Group, iDispatchHub, iCoach360, and CarrierLens. He has spent more than two and a half decades in the transportation industry, with experience spanning Schneider National, Prime Inc., McLane Foodservice Distribution, and Lowe's Companies. Adam's work focuses on helping small fleet owners and owner-operators build businesses that are financially sound, operationally structured, and built to last. His teaching philosophy centers on breakeven intelligence, cost-per-mile clarity, and sustainable growth over motivation-driven hustle. Through projects like The Playbook at FreightWaves, he delivers education, strategy, and industry analysis for carriers running one truck or twenty — covering compliance, freight markets, driver management, and the business decisions that separate operators who survive from those who scale.
