Our market is defined by uncertainty.
Today, tighter margins and growing pressure to deliver consistent performance have made customer relationships more urgent than ever. Promising aggressive ETAs is an easy move, but there’s a better choice. In the long run, consistency, not speed, is the king of customer relations. Impressive speed means little if customers can’t count on it. But deliver consistently on your promises and your customers learn to trust you.
Reliability itself springs from eliminating the variables that catch you out. PrePass® Mile Marker 2026: The National Bypass Impact Index helps your evaluations. It’s the first national benchmark for understanding how weigh station bypass affects fleet efficiency.
For fleet owners, a weigh station inspection can be a crucial variable in time and overhead. Bypassing a weigh station helps your drivers meet their itineraries. Bypass a hundred and you’re well on the road to sustainable predictability.
Small efficiencies multiplied across your fleet give you enormous gains and a towering advantage over your competitors that is impossible to ignore.
The hidden cost of operational friction.
Inefficient workflows directly threaten your profitability. Here’s what we learned from the 2026 Impact Index:
Small delays add up to real cost. Each weigh station pull-in drains drive time, fuel, and operational costs. Across 100 or 500 trucks it’s a significant erosion of your operational profit. So, let’s do the math for a 100-truck fleet averaging 7 bypasses a week:
| Metric | Per bypass | Per truck/year (7/week) | 100-Truck Fleet/Year |
| Time saved | 7 minutes | 42 hours | 4,200 hours |
| Fuel saved | ½ gallon | 182 gallons | 18,200 gallons |
| Cost saved | $10.65 | $3,877 | $387,700 |
Source: Mile Marker 2026: The National Bypass Impact Index
Saving those costs protects your margin as the market pressures your pricing. You’ve been absorbing these “invisible” costs and that should stop.
Delays build into disruptions.
The operational reality cannot be ignored, with missed stops, scheduling turmoil, and detention costs as buffer time disappears. It is so much harder to recover from these variations when they go wrong in combination.
The net effect on your fleet is that your bottom line suffers. And so does your reputation with shippers.
What do your customers value? Reliability.
Let’s look at freight from the shipper’s (your customer’s) point of view. For smooth operations, shippers make critical planning, staffing, and inventory decisions around their delivery expectations. Every missed appointment or late delivery eats away at their trust. Detentions are a telling symptom of inconsistency and strain direct costs and customer relationships alike. But detentions don’t start at the dock. They start with the small disruptions along a route that quietly cut into a driver’s available time. Less friction along the route helps you hold to your schedule. And that is how good operational design replaces luck.
Dependability and trust may seem a little soft, but they have very concrete benefits for your operations. Consistency shows your customers that you have a mature operation they can depend on. That attracts and sustains businesses. During rate negotiations, do you want to be seen as unpredictable? Or as a company that meets commitments?
Speed vs. variability: Reliability wins.
| Factor | “Faster” Approach | “Reliability” Approach |
| Focus | Reducing average trip time | Reducing trip time variance |
| Planning value | Limited: Averages mask outliers | High: Predictable windows enable precision |
| Customer perception | “Great runs offset by missed windows” | “We can count on them” |
| Detention risk | Higher: Tighter buffers mean more exposure. | Lower: Consistency builds slack into the system |
| Competitive position | Commoditized on rate | Differentiated on performance |
Don’t wait in line.
The weigh station process often leads to logistical setbacks and lost time. Predictable schedules start with reducing inspection-related disruptions such as inspection time and long lines.
Approaching a weigh station, PrePass electronically identifies the truck and verifies its credentials against more than 100 federal, state, and provincial databases. A green light means proceed; a red light or “Pull In” alert means stop for inspection. Both driver and enforcement see the same result.
Fleets that maintain strong safety performance and favorable ISS scores earn more consistent bypass opportunities. Inspections still happen, but compliant carriers experience fewer unplanned interruptions.
Bypassing keeps low-risk trucks moving, creating more predictable and less congested roads for all drivers. This efficiency also allows state enforcement to redirect their focus toward higher-risk safety concerns.
Bypass explained.
Bypass status is a privilege based on performance rather than a permanent right. Even for qualified carriers, random and periodic inspections remain mandatory. Eligibility for pre-qualified vehicles is determined by:
- FMCSA safety data and ISS scores
- Inspection history and compliance records
Schedule adherence beats speed.
This isn’t just talk. National data now measures how these small improvements add up to serious advantages.
All that time returned to drivers is time returned to your fleet’s planning, reliability, and execution. Reducing bottlenecks does more than save money. It reduces the variables that make operations unpredictable.
Let’s do the math.
Mile Marker 2026: The National Bypass Impact Index establishes a national equation based on over 1.6 billion bypass events across 40 states.
- Per bypass savings (average)
- 7 minutes of drive time
- ½ gallon of fuel
- $10.65 in operational costs
- 500-truck fleet at 7 bypasses/week
- 21,000 hours returned annually
- 91,000 gallons of fuel saved
- ~$1.94 million in operational cost savings
Compete on reliability.
With today’s market uncertainty and tight margins, fleets that reduce friction and improve predictability outperform those who focus on speed.
Top fleets build reliability into their basic operations to reduce variability, protect margins, and prioritize predictable performance. Bypass is a critical piece of operational strategy. It’s your tool to build the reliability that wins and retains business.
A thriving fleet depends on how consistently your trucks move and how effectively their disruptions are minimized.
Compare your fleet against the Mile Marker 2026 benchmark.
