How to Create a Maintenance Budget You Can Stick To
Most trucking businesses bleed cash on maintenance not because repairs are expensive—but because the budget behind them is broken; this article walks you through how to build a real maintenance budget that protects your uptime, your wallet, and your future.
(Photo: Jim Allen, Freightwaves. In the spring of 2026, dealers across the country are taking in more equipment than they have seen in years as carriers exit the market under regulatory pressure.)
If your maintenance budget feels like a moving target, you’re not alone. Most small fleet owners and owner-operators either guess at their maintenance costs—or worse, react to them only after something breaks. That’s not a strategy. That’s survival. And in this industry, running your business in survival mode will kill your margins faster than a blown turbo.
A real maintenance budget isn’t about predicting every part failure. It’s about putting structure behind one of the most controllable—but commonly ignored—parts of your business. When done right, your maintenance budget becomes a competitive weapon. It protects your uptime, keeps drivers safe, makes your equipment last longer, and shields you from the chaos of emergency repairs.
You don’t need to be a CPA or diesel tech to build one. You just need a system. This article breaks down that system in plain terms—so you can stop flying blind and start leading your fleet like a business owner, not a fireman.
Why Most Maintenance Budgets Don’t Work
Let’s start with the truth.
Most folks throw a number out like $0.10 per mile and call it a day. But when a DEF system fails or a clutch job hits them for $4,000, they realize real quick that guesswork doesn’t cut it.
Here’s what usually goes wrong:
  • No data tracking
  • No separation between preventive and corrective costs
  • Treating PMs as optional
  • Over-relying on warranties
  • Underestimating labor and downtime
A proper maintenance budget has three core parts:
  1. Preventive Maintenance (PM)
  2. Scheduled Repairs & Replacements
  3. Emergency & Unscheduled Breakdowns
If you’re not budgeting for all three, you’re setting yourself up for a cash flow disaster.
Step 1: Know Your Cost Per Mile—The Right Way
Start with the data that matters most: how much you’re actually spending on maintenance per mile.
Pull the last 6–12 months of maintenance records—this includes oil changes, tires, brakes, sensors, shop labor, mobile repairs, towing, parts, and even fluid top-offs. Divide the total by the number of miles your truck or fleet ran.
Formula:
Total Maintenance Costs ÷ Total Miles = Maintenance Cost Per Mile (CPM)
If your number’s under $0.10/mile, you’re either lucky, ignoring major repairs, or missing expenses. Realistically, it should fall between $0.12 and $0.18 per mile depending on truck age, make, and how well you stay on top of PMs.
Use that baseline CPM to forecast next quarter and next year’s maintenance spend based on your mileage goals. This gives you a realistic number to work with—not a shot in the dark.
Step 2: Separate Preventive from Corrective Costs
Treating all maintenance as one lump sum is a mistake. Preventive maintenance is planned. It’s predictable. And it’s cheaper in the long run.
Corrective maintenance—your “uh-oh” moments—are unpredictable and expensive.
Break them down like this:
Preventive:
  • Oil and filter changes
  • Tire rotations
  • Brake inspections
  • Fluid flushes
  • Belt and hose replacements
  • DPF cleanings
Corrective:
  • Air compressor failure
  • DEF system issues
  • Blown turbo
  • Faulty EGR valve
  • Injector replacement
  • Transmission repair
Build your budget to handle both—but prioritize the preventive. Why? Because every PM service you delay increases the odds you’ll face a more expensive, unplanned failure later.
Step 3: Build a Maintenance Reserve That’s Non-Negotiable
You don’t create a budget to hope repairs don’t happen—you build one because they will.
Set up a maintenance reserve account—separate from your operating cash. This is money set aside specifically for truck maintenance and repairs. No exceptions.
How much should go in?
Use your CPM and mileage goals. Let’s say your truck runs 10,000 miles/month and your real CPM is $0.15. That’s $1,500/month.
Transfer that amount every single month into your reserve account.
And here’s the part that matters—don’t dip into it for other business expenses. That reserve isn’t a slush fund. It’s the wall between you and a roadside breakdown that costs you two loads, a hotel stay, and $7,000 in repairs.
Step 4: Budget Based on Truck Age and Condition
Not all trucks are created equal—and neither are their maintenance needs.
If you’re running late-model equipment under warranty, your budget will look different than someone with a 2016 Cascadia pushing 800,000 miles. Older trucks need more love. That means more cash.
Here’s a general guideline:
  • Newer Trucks (0–3 years): $0.10–$0.12 CPM
  • Mid-Life Trucks (3–7 years): $0.13–$0.16 CPM
  • Older Trucks (7+ years): $0.17–$0.22 CPM
Don’t just go by age. Look at maintenance history, engine type, and previous issues. For example, trucks with DD15s often see aftertreatment system issues around the 500k–600k mark. Budget for it before it hits.
Step 5: Schedule Major Repairs in Advance
Here’s where most owner-operators miss the mark: They treat major component failures like surprises. But most parts give you warning signs—or have recommended replacement intervals.
Start forecasting major expenses 6–12 months in advance.
Examples:
  • Clutch replacement at 500,000–700,000 miles
  • Suspension bushings at 400,000–600,000 miles
  • DPF replacements around 480,000 miles
If you know you’ve got a component nearing end-of-life, build that cost into your monthly budget now—even if the failure hasn’t happened yet.
This gives you time to plan downtime, negotiate shop rates, and avoid the financial gut punch of emergency work.
Step 6: Track Downtime Costs
Your maintenance budget shouldn’t just include parts and labor. It should account for lost revenue when your truck is parked.
Every day you’re down, you’re losing opportunity—and that costs more than you think.
Example:
If your truck normally grosses $1,200/day and you’re down for 3 days waiting on a part? That’s $3,600 in revenue loss—on top of the repair cost.
Track these numbers so you understand the true cost of neglecting maintenance. It’s not just about the shop bill. It’s about protecting uptime.
Step 7: Use a Maintenance Management System
Whether you have one truck or ten, keeping track of every repair, PM service, and shop visit manually will catch up with you.
Use software like Fleetio, Whip Around, or even a simple Excel tracker to document:
  • Service dates and types
  • Mileage at service
  • Vendor and cost
  • Next scheduled service date
This lets you build history, spot patterns, and catch repeat failures early. It also helps with warranty claims and resale value when it’s time to move equipment.
If you’re still relying on memory or scribbled notes, you’re not budgeting—you’re gambling.
Step 8: Review and Adjust Quarterly
The market shifts. Shop rates go up. Parts availability changes. Your trucks age.
That’s why a one-time budget isn’t enough. Set a quarterly review on your calendar—non-negotiable.
Ask yourself:
  • Did I go over budget? Why?
  • Were most of my costs preventive or corrective?
  • Did I have unexpected breakdowns? What caused them?
  • Is my CPM going up or down?
Use that feedback to adjust your next quarter’s budget. This isn’t guesswork—it’s leadership by the numbers.
Final Word
A maintenance budget you can stick to isn’t about perfection—it’s about preparation. It’s not just a spreadsheet or a line item—it’s a commitment to running your fleet like a business, not a gamble.
Stop thinking of maintenance as a cost. Start thinking of it as protection—against downtime, against driver turnover, against missed loads, and against financial chaos.
Put structure behind your maintenance process. Track everything. Budget proactively. Build reserves. And take pride in running trucks that are ready to move freight every single day.
Because in this business, the ones who win long-term aren’t the ones with the shiniest trucks. They’re the ones who knew how to keep their trucks moving—and their books balanced.
That’s how you run a business that lasts.
Adam Wingfield
Adam L. Wingfield is the Editor in Chief at FreightWaves and the Founder and CEO of Innovative Business Development Group, Inc. — the parent company behind Innovative Logistics Group, iDispatchHub, iCoach360, and CarrierLens. He has spent more than two and a half decades in the transportation industry, with experience spanning Schneider National, Prime Inc., McLane Foodservice Distribution, and Lowe's Companies. Adam's work focuses on helping small fleet owners and owner-operators build businesses that are financially sound, operationally structured, and built to last. His teaching philosophy centers on breakeven intelligence, cost-per-mile clarity, and sustainable growth over motivation-driven hustle. Through projects like The Playbook at FreightWaves, he delivers education, strategy, and industry analysis for carriers running one truck or twenty — covering compliance, freight markets, driver management, and the business decisions that separate operators who survive from those who scale.
