Freight Factoring Rates: How Much Does Factoring Really Cost?
What does freight factoring actually cost—in real dollars?
(Photo: Jim Allen/FreightWaves.)
If you’re running loads consistently but waiting 30, 45, or 60 days to get paid, freight factoring becomes less of a luxury and more of an operational necessity. But before using it, there’s a straightforward question every carrier asks:
This guide breaks it down without fluff. No vague answers. Only how pricing works, what you’ll actually pay, and how to evaluate whether it makes sense for your business.
What Freight Factoring Rates Typically Look Like
Freight factoring is usually priced as a percentage of the invoice value. That percentage is the discount rate.
Standard industry ranges
  • Recourse factoring: 1.5% to 3.0% per invoice
  • Non-recourse factoring: 2.5% to 5.0% per invoice
These are not arbitrary. They reflect risk.
In recourse, you, as the carrier, retain the risk if a broker doesn’t pay. In non-recourse factoring, the factoring company assumes the risk (under specific conditions), which is why the rate is higher.
Flat vs. Tiered Rates
There are two main pricing structures in the industry:
Flat Rate (Most Transparent):
  • Usually, 2.5% to 5% in non-recourse structures.
  • You pay a fixed percentage regardless of when the broker pays.
  • Example: 3% flat on a $2,000 invoice = $60 total cost
Simple, predictable, and easy to calculate upfront.
Tiered Rate (More common, Less Straightforward):
  • You pay a base rate for a set period (typically 30 days), then additional fees if payment takes longer than that.
  • Example:
    • 2% for the first 30 days
    • +0.5% every 10 days after
If a broker pays in 50 days, your cost might look like:
2% + 1% (two extra periods) = 3% total
Here is where costs quietly increase.
What Most Carriers Don’t Realize
Tiered pricing often looks cheaper upfront, but in real-world trucking, where payments frequently extend beyond 30 days, it tends to end up equal to or more expensive than a flat rate.
For that reason, tiered structures only make sense when you’re working with brokers that have a consistent, verified payment history. Otherwise, you’re taking on timing risk that directly increases your cost.
Spot Vs. Contract Factoring
Beyond how rates are structured, pricing also depends on how often you factor.
There are two main approaches:
Spot Factoring (Occasional Use)
  • You choose which loads to factor, with no long-term agreement
  • Higher cost per invoice due to lower predictability
  • Typical range: 3% to 6% per invoice (non-recourse)
Contract Factoring (Ongoing Relationship)
  • You factor invoices continuously under an agreement
  • May include operational requirements (volume minimums, concentration limits, etc.)
  • Lower rates due to consistent volume and predictability
  • Typical range: 2.0% to 4.0% per invoice (non-recourse)
What Actually Drives the Price Difference
The difference between spot and contract pricing comes down to risk, volume, and predictability.
With spot factoring, the factor has limited visibility into your future activity.
With contract factoring, they can model your volume, broker mix, and cash flow behavior more accurately.
That predictability reduces uncertainty and directly lowers your rate.
Practical Takeaway
Most carriers start with the idea that they want flexibility. But in practice, if you’re factoring consistently, contract pricing is almost always more cost-effective. If you only factor occasionally or during tight periods, spot factoring can make sense despite the higher rate.
The key is being honest about your operation.
If factoring becomes part of your weekly cash flow, you are already operating like a contract client, but paying spot-level pricing.
Other Fees That Increase the Real Cost
At this point, many carriers assume the quoted rate is the full cost of factoring. It usually isn’t.
The percentage a factor advertises is only part of the equation. In practice, the real cost can climb due to additional fees tied to how funds are sent, how fast you need them, how often you factor, or how your agreement is structured.
Individually, these charges may seem small. In practice, they stack and materially increase your total cost.
  1. ACH / Wire Transfer Fees
Most factoring companies charge a fee every time they send funds.
ACH transfers typically range from $2 to $15, while wires can range from $10 to $35. On a single transaction, that’s negligible. Over dozens of invoices per month, it becomes material.
Example:
If you factor 20 invoices per month and pay a $10 transfer fee each time, that’s $200 per month on top of your rate.
  1. Same-Day or Expedited Funding Fees
Some companies promote fast funding, but charge extra if you want access to funds the same day.
This can show up as a percentage (0.25% to 1.0% per invoice) or as a flat fee per transaction. On paper, the increase looks small. In practice, it raises your effective rate across every load.
  1. Monthly Minimum Fees and Requirements
Certain contracts require you to factor a minimum volume. If you don’t meet it, you pay a penalty ranging from $250 to $1,000+ per month.
For carriers with inconsistent volume, this creates a hidden cost: your effective rate increases during slower months, exactly when cash flow is already tight.
  1. Contract Termination Fees
One of the most overlooked elements.
Some agreements include cancellation fees if you exit early. These can range from $500 to $5,000 or more, depending on the contract structure.
A competitive rate loses value quickly if it locks you into a costly agreement.
  1. Credit Check Fees
Some factors charge for onboarding or evaluating new brokers.
Credit checks typically cost $10 to $50 per customer, while setup fees range from $100 to $500.
These are not always significant on their own, but they contribute to the total cost of doing business.
  1. Chargebacks
One of the most important costs in factoring is not always listed as a fee. It appears when an invoice is funded but later charged back to the carrier.
This is common in recourse programs and can still happen in limited non-recourse structures if a broker does not pay, disputes the load, or becomes insolvent.
The impact is immediate. If a factor advanced 90% on a $3,000 invoice, the carrier may need to return $2,700 out of pocket.
That is why it is critical to understand when a chargeback can happen, not just what the rate is.
Real Cost Example (What You Actually Pay)
To understand how this works in practice, you have to look beyond percentages and combine everything.
Let’s take a realistic scenario:
A carrier factors $20,000 per week at a 3% rate.
At first glance, the math seems simple:
$20,000 × 3% = $600 per week
Over a month, that becomes approximately $2,400 in factoring fees.
Now layer in the operational costs:
  • Transfer fees: ~$150 per week → $600 per month
  • Additional fees (minimums, admin, etc.): ~$200 per month
The real monthly cost is no longer $2,400.
It comes out closer to $3,200 per month.
Why the Quoted Rate Is Not Enough
A carrier may think they are paying 3%, when the real monthly cost is closer to 4% once transfer fees, funding fees, and contract-related charges are included.
That difference may seem small, but it compounds quickly. As George McWilliams, VP of Business Development at Summar Financial, put it: “That 1% on a thousand bucks can turn to 6, 7% by the time you’ve factored everything in.”
At $50,000 in monthly invoices, the gap between 3% and 4% is $500 per month, or $6,000 per year.
This is why focusing only on the rate is misleading. In some cases, the real cost is not just extra fees, but also the risk of chargebacks that push unpaid or disputed invoices back onto the carrier.
The better question is:
What is my total cost after every fee tied to funding, transfers, volume requirements, and contract structure?
 Read more: 5 Key Questions Small Carriers Should Ask Freight Factoring Companies
Is Factoring Worth It? A Real Cost Comparison
At this point, the question shifts.
It’s no longer just about cost. It’s about what that cost enables.
Without factoring, you operate on delayed cash flow. You wait 30 to 45 days to get paid, which means fuel, maintenance, and growth all depend on available cash or credit.
In many cases, that leads to relying on credit cards or short-term loans, which introduce interest costs, repayment pressure, and reduce your financial flexibility over time.
With factoring, you convert invoices into immediate liquidity. That changes how fast you can move.
Let’s put that into numbers.
If factoring costs $3,000 per month, but allows you to run two additional loads per week at $400 profit per load:
2 loads × 4 weeks × $400 = $3,200
In that scenario, factoring offsets its own cost.
If it doesn’t help you increase revenue, reduce operational stress, or improve consistency, then it may not be the right tool.
What a Transparent Factoring Structure Looks Like
After reviewing how factoring rates work, one thing becomes clear: the real issue is not just the percentage quoted. It is whether the full cost is disclosed from the beginning.
Two factoring companies can quote the same rate and deliver completely different real costs. One may rely on transfer fees, funding charges, minimums, or contract penalties that only surface once the relationship is underway. Another keeps pricing simple and predictable from the start. That difference determines whether factoring becomes a tool for growth or an expense that keeps quietly rising over time.
A transparent program makes it easy for a carrier to understand what they are paying for, what is included, and what will not appear as a surprise later. That sounds like a basic expectation. In practice, it is less common than it should be.
The question worth asking before signing is not just “what is your rate?” It is what exactly is included, what is not, and what will this relationship actually cost once you are running loads every week. The factoring company that answers those questions clearly and upfront is almost always the better long-term partner, regardless of where the initial rate lands relative to the competition.
If you want a factoring program with transparent pricing, same-day funding, real non-recourse protection, and operational support that actually helps, contact Summar to build a cash flow solution that fits your operation.
Contributed Content
Note: FreightWaves occasionally publishes commentary from industry sources with expertise, information and opinion on current transportation topics. The opinions expressed in the article are solely those of the author and not necessarily those of FreightWaves. Submissions to FreightWaves are subject to editing.
